LeCroyOscilloscopeDeviceDriverConfiguration
| Note: | This page is used to show the configuration of the LeCroy oscilloscope device drivers. This page can now easily be embedded on all relevant device driver pages. |
The following tabs are available in the advanced configuration of the LeCroyOscilloscopeDeviceDriverConfiguration:
On the Channel Selection tab, the desired channel that should be measured can be selected.
| Channel 1 will be used as the measurement input. |
| Channel 2 will be used as the measurement input. |
| Channel 3 will be used as the measurement input. |
| Channel 4 will be used as the measurement input. |
| The 'Measures' as they can be configured on the LeCroy oscilloscope will be used. |
Some LeCroy oscilloscope devices only have 2 input channels, and in that case the configuration dialog will only show the channels that are supported.
Channel[edit]
If one of the Channel options is selected, the EUT Monitoring device in RadiMation® will use the following mapping:
| Channel | Measurement | Maximum value |
| 1 | Minimum amplitude | 353.55 V |
| 2 | Maximum amplitude | 353.55 V |
| 3 | Amplitude | 353.55 V |
| 4 | Peak to Peak voltage | 707.1 V |
| 5 | RMS value | 250 V |
| 6 | Frequency in MHz | 200 MHz |
| 7 | Dutycycle | 100 % |
| 8 | Trace dump |
The 'Trace dump' mode retrieves the trace data of the selected channel, and then creates a DUMP_<FREQ>MHz_<YEAR>-<MONTH>-<DAY>_<HOUR>-<MINUTE>-<SEC>.CSV file in the C:\Work\ directory that contains the raw data of the complete trace. The graph in RadiMation® thus doesn't show any logical information, however all the raw data of the traces is present in several files in the C:\Work\ directory.
Measures[edit]
If the Measures options is selected, the EUT Monitoring device in RadiMation® is retrieving the values from the 'Measure' that are configured in the LeCroy oscilloscope itself. The to be measured value can thus be configured in the LeCroy by using one of the available measurement functions. See the end-user manual of the LeCroy on how these 'Measures' can be configured. The measure configuration in the LeCroy also includes from which input channel the value should be measured. These measures are numbered in the LeCroy, and the same numbering is used in the RadiMation®. The EUT Monitoring channel 2 will thus use the value of Measure 2 in the LeCroy.
