LogiMetrics AN8100Q
The LogiMetrics AN8100Q device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the LogiMetrics AN8100Q:
The frequency range of the LogiMetrics AN8100Q as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the LogiMetrics AN8100Q.
Be careful changing these settings as RadiMation® is no longer able to verify if the LogiMetrics AN8100Q is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
