The Luthi CR 100 A device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Luthi CR 100 A:
The frequency range of the Luthi CR 100 A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Luthi CR 100 A.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Luthi CR 100 A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
