Luthi FTC 40X15 E
The Luthi FTC 40X15 E device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Luthi FTC 40X15 E:
The frequency range of the Luthi FTC 40X15 E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Luthi FTC 40X15 E.
Be careful changing these settings as RadiMation® is no longer able to verify if the Luthi FTC 40X15 E is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Luthi FTC 40X15 E
- Google image search: Luthi FTC 40X15 E
