Luthi FT 14X15
The Luthi FT 14X15 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Luthi FT 14X15:
The frequency range of the Luthi FT 14X15 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Luthi FT 14X15.
Be careful changing these settings as RadiMation® is no longer able to verify if the Luthi FT 14X15 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Luthi FT 14X15
- Google image search: Luthi FT 14X15
