Lüthi FGZ 40X15 E
The Lüthi FGZ 40X15 E device driver is a Absorbing Clamp which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Lüthi FGZ 40X15 E:
The frequency range of the Lüthi FGZ 40X15 E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Lüthi FGZ 40X15 E.
Be careful changing these setting as RadiMation® is no longer able to verify if the Lüthi FGZ 40X15 E is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Lüthi FGZ 40X15 E
- Google image search: Lüthi FGZ 40X15 E
