Lüthi FTC 101
The Lüthi FTC 101 device driver is a Absorbing Clamp which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Lüthi FTC 101:
The frequency range of the Lüthi FTC 101 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Lüthi FTC 101.
Be careful changing these setting as RadiMation® is no longer able to verify if the Lüthi FTC 101 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Lüthi FTC 101
- Google image search: Lüthi FTC 101
