MICRORAD NHT310
The MICRORAD NHT310 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the MICRORAD NHT310:
| The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable. |
| If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop. |
The frequency range of the MICRORAD NHT310 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the MICRORAD NHT310.
Be careful changing these settings as RadiMation® is no longer able to verify if the MICRORAD NHT310 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
It is impossible to control the MICRORAD NHT310 directly from RadiMation®, it is however possible that the RadiMation® software contacts the MicroLink software of MICRORAD to retrieve the measured field strength. Use the following steps to enable the field strength measurements of the MICRORAD NHT310 in RadiMation®
- Install the MicroLink software of MICRORAD on the same PC on which RadiMation® is running. (Version 2.10 or newer of MicroLink should be installed) ( http://www.microrad.it/en/download/software-2/ )
- Connect the MICRORAD NHT310 to the PC
- Start the MicroLink software, select the 'Meter' menu and select the 'Share' option.
- Note the UDP port number that is specified (63452 by default), and press the 'Blue Play'-button
- In RadiMation® create a new Field sensor device driver for the MICRORAD NHT310
- Press the 'Advanced' button of the newly created device driver and select the 'Communication' tab.
- To connect to the MicroLink software, select the 'UDP' method and press the 'Configure' button. The address should be: "udp://localhost:63452", where 63452 is the same number as in the UDP port setting of the MicroLink software.
- Now close all the dialogs of the advanced device driver configuration
- The MICRORAD NHT310 device driver can now be used to get the field strength from the probe itself.
