MITEQ AFSX4-00101200-42-10P-N
The MITEQ AFSX4-00101200-42-10P-N device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the MITEQ AFSX4-00101200-42-10P-N:
The frequency range of the MITEQ AFSX4-00101200-42-10P-N as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the MITEQ AFSX4-00101200-42-10P-N.
Be careful changing these settings as RadiMation® is no longer able to verify if the MITEQ AFSX4-00101200-42-10P-N is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: MITEQ AFSX4-00101200-42-10P-N
- Google image search: MITEQ AFSX4-00101200-42-10P-N
