Marconi 2023 (FM Modulated)
The Marconi 2023 (FM Modulated) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Marconi 2023 (FM Modulated):
The frequency range of the Marconi 2023 (FM Modulated) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Marconi 2023 (FM Modulated).
Be careful changing these settings as RadiMation® is no longer able to verify if the Marconi 2023 (FM Modulated) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Marconi 2023 (FM Modulated)
- Google image search: Marconi 2023 (FM Modulated)
