Milmega AS0102-65
The Milmega AS0102-65 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0102-65:
The frequency range of the Milmega AS0102-65 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Milmega AS0102-65.
Be careful changing these settings as RadiMation® is no longer able to verify if the Milmega AS0102-65 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
