Milmega AS0104 (remote low band)
The Milmega AS0104 (remote low band) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0104 (remote low band):
The frequency range of the Milmega AS0104 (remote low band) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Milmega AS0104 (remote low band).
Be careful changing these settings as RadiMation® is no longer able to verify if the Milmega AS0104 (remote low band) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Note: When connecting the amplifier via LAN please use the TCP/IP stream and use port 5025. Where you see the ip-adress 192.01.01.01 use the ip-adress of the amplifier.
