Milmega AS0860-100D
The Milmega AS0860-100D device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0860-100D:
The frequency range of the Milmega AS0860-100D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Milmega AS0860-100D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Milmega AS0860-100D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
