Milmega AS0860B (remote high band)
The Milmega AS0860B (remote high band) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega AS0860B (remote high band):
The frequency range of the Milmega AS0860B (remote high band) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Milmega AS0860B (remote high band).
Be careful changing these settings as RadiMation® is no longer able to verify if the Milmega AS0860B (remote high band) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Milmega AS0860B (remote high band)
- Google image search: Milmega AS0860B (remote high band)
