Milmega ASM 1000 Internal Coupler
The Milmega ASM 1000 Internal Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega ASM 1000 Internal Coupler:
The frequency range of the Milmega ASM 1000 Internal Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Milmega ASM 1000 Internal Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the Milmega ASM 1000 Internal Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Milmega ASM 1000 Internal Coupler
- Google image search: Milmega ASM 1000 Internal Coupler
