Milmega RF 1000
The Milmega RF 1000 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Milmega RF 1000:
The frequency range of the Milmega RF 1000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Milmega RF 1000.
Be careful changing these settings as RadiMation® is no longer able to verify if the Milmega RF 1000 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Milmega RF 1000
- Google image search: Milmega RF 1000
