Mini-Circuits ZFL-1000ln
(Redirected from Mini Circuits ZFL-1000ln)
The Mini-Circuits ZFL-1000ln device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Mini-Circuits ZFL-1000ln:
The frequency range of the Mini-Circuits ZFL-1000ln as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Mini-Circuits ZFL-1000ln.
Be careful changing these settings as RadiMation® is no longer able to verify if the Mini-Circuits ZFL-1000ln is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
