Mini-Circuits ZVA-183-S+
The Mini-Circuits ZVA-183-S+ device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Mini-Circuits ZVA-183-S+:
The frequency range of the Mini-Circuits ZVA-183-S+ as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Mini-Circuits ZVA-183-S+.
Be careful changing these setting as RadiMation® is no longer able to verify if the Mini-Circuits ZVA-183-S+ is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Mini-Circuits ZVA-183-S+
- Google image search: Mini-Circuits ZVA-183-S+
