The Multicomp pro MP730027 device driver is a AD Converter, Multimeter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Multicomp pro MP730027:
The frequency range of the Multicomp pro MP730027 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Multicomp pro MP730027.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Multicomp pro MP730027 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
Communication Streams
Expected response
The expected *IDN? response of a device. It can be changed in the case the commands are the same for another device for which no RadiMation® driver is available yet.
Restore default
Restores the original Exepected response.
The device driver can be configured to be reset on initialization.
Reset device during initialization
Configure that the device is reset when initialized.
Delay after reset
The time in seconds to wait after resetting the device
AC Volt
Select the AC voltage measurement as the measurement type.
AC Current
Select the DC voltage measurement as the measurement type.
DC Volt
Select the AC current measurement as the measurement type.
DC Current
Select the DC current measurement as the measurement type.
Frequency
Select the frequency measurement as the measurement type. Only Middle speed is possible.
Period
Select the period measurement as the measurement type. Only Middle speed is possible.
Temperature
Select the temperature measurement as the measurement type. Only Middle speed is possible.
Resistance
Select the resistance measurement as the measurement type.
Low
Selects a low measurement speed, with a long trigger interval.
Middle
Selects medium measurement speed, with a medium trigger interval.
Fast
Selects a fast measurement speed with a shrot trigger interval.
