NoiseKen NA15K80MF50C
The NoiseKen NA15K80MF50C device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the NoiseKen NA15K80MF50C:
The frequency range of the NoiseKen NA15K80MF50C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the NoiseKen NA15K80MF50C.
Be careful changing these settings as RadiMation® is no longer able to verify if the NoiseKen NA15K80MF50C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
