NoiseKen NA25MF1G2010C
The NoiseKen NA25MF1G2010C device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the NoiseKen NA25MF1G2010C:
The frequency range of the NoiseKen NA25MF1G2010C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the NoiseKen NA25MF1G2010C.
Be careful changing these settings as RadiMation® is no longer able to verify if the NoiseKen NA25MF1G2010C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
