NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz
The NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz:
The frequency range of the NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz.
Be careful changing these settings as RadiMation® is no longer able to verify if the NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz
- Google image search: NoiseKen NA80MF3G201003 (Band 2) 220 - 1000 MHz
