OSR C21A8
The OSR C21A8 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the OSR C21A8:
The frequency range of the OSR C21A8 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the OSR C21A8.
Be careful changing these settings as RadiMation® is no longer able to verify if the OSR C21A8 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
