Ophir RF 5019E
The Ophir RF 5019E device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ophir RF 5019E:
The frequency range of the Ophir RF 5019E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Ophir RF 5019E.
Be careful changing these settings as RadiMation® is no longer able to verify if the Ophir RF 5019E is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Ophir RF 5019E
- Google image search: Ophir RF 5019E
