Ophir RF 5125
The Ophir RF 5125 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ophir RF 5125:
The frequency range of the Ophir RF 5125 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Ophir RF 5125.
Be careful changing these settings as RadiMation® is no longer able to verify if the Ophir RF 5125 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Ophir RF 5125
- Google image search: Ophir RF 5125
