Ophir RF 6544 Pulse TWT
The Ophir RF 6544 Pulse TWT device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ophir RF 6544 Pulse TWT:
The frequency range of the Ophir RF 6544 Pulse TWT as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Ophir RF 6544 Pulse TWT.
Be careful changing these settings as RadiMation® is no longer able to verify if the Ophir RF 6544 Pulse TWT is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Ophir RF 6544 Pulse TWT
- Google image search: Ophir RF 6544 Pulse TWT
