PMM ER8000 LISN
The PMM ER8000 LISN device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM ER8000 LISN:
The frequency range of the PMM ER8000 LISN as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the PMM ER8000 LISN.
Be careful changing these settings as RadiMation® is no longer able to verify if the PMM ER8000 LISN is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: PMM ER8000 LISN
- Google image search: PMM ER8000 LISN
