PMM L3-500
The PMM L3-500 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the PMM L3-500:
The frequency range of the PMM L3-500 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the PMM L3-500.
Be careful changing these settings as RadiMation® is no longer able to verify if the PMM L3-500 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
