Pasternack PE9850-20 Horn
The Pasternack PE9850-20 Horn device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Pasternack PE9850-20 Horn:
The frequency range of the Pasternack PE9850-20 Horn as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Pasternack PE9850-20 Horn.
Be careful changing these settings as RadiMation® is no longer able to verify if the Pasternack PE9850-20 Horn is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Pasternack PE9850-20 Horn
- Google image search: Pasternack PE9850-20 Horn
