Pearson Electronics 8705C
The Pearson Electronics 8705C device driver is a Current Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Pearson Electronics 8705C:
The frequency range of the Pearson Electronics 8705C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Pearson Electronics 8705C.
Be careful changing these settings as RadiMation® is no longer able to verify if the Pearson Electronics 8705C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Pearson Electronics 8705C
- Google image search: Pearson Electronics 8705C
