Personal Computer
The Personal Computer device driver is a AmplifierVoltage, dips and interrupts generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Personal Computer:
The frequency range of the Personal Computer as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Personal Computer.
Be careful changing these settings as RadiMation® is no longer able to verify if the Personal Computer is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
