Power supply
The Power supply device driver is a AmplifierVoltage, dips and interrupts generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Power supply:
The frequency range of the Power supply as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Power supply.
Be careful changing these settings as RadiMation® is no longer able to verify if the Power supply is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
