Prana AP32DR216 FW Coupler
The Prana AP32DR216 FW Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana AP32DR216 FW Coupler:
The frequency range of the Prana AP32DR216 FW Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Prana AP32DR216 FW Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the Prana AP32DR216 FW Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
