Prana DP 1300
The Prana DP 1300 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana DP 1300:
The frequency range of the Prana DP 1300 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Prana DP 1300.
Be careful changing these settings as RadiMation® is no longer able to verify if the Prana DP 1300 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
