Prana DP 70D
The Prana DP 70D device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana DP 70D:
The frequency range of the Prana DP 70D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Prana DP 70D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Prana DP 70D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
