The Prana N-MT 500 Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Prana N-MT 500 Coupler:
The frequency range of the Prana N-MT 500 Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Prana N-MT 500 Coupler.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Prana N-MT 500 Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
