R+B Inc. ICN 101 Jig
The R+B Inc. ICN 101 Jig device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the R+B Inc. ICN 101 Jig:
The frequency range of the R+B Inc. ICN 101 Jig as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the R+B Inc. ICN 101 Jig.
Be careful changing these setting as RadiMation® is no longer able to verify if the R+B Inc. ICN 101 Jig is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: R+B Inc. ICN 101 Jig
- Google image search: R+B Inc. ICN 101 Jig
