RF Lambda Configurable Coupler
The RF Lambda Configurable Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the RF Lambda Configurable Coupler:
The frequency range of the RF Lambda Configurable Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the RF Lambda Configurable Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the RF Lambda Configurable Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
