RF Power Components Inc. RFP-6010
The RF Power Components Inc. RFP-6010 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the RF Power Components Inc. RFP-6010:
The frequency range of the RF Power Components Inc. RFP-6010 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the RF Power Components Inc. RFP-6010.
Be careful changing these settings as RadiMation® is no longer able to verify if the RF Power Components Inc. RFP-6010 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: RF Power Components Inc. RFP-6010
- Google image search: RF Power Components Inc. RFP-6010
