RF Spin DRH18
The RF Spin DRH18 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the RF Spin DRH18:
The frequency range of the RF Spin DRH18 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the RF Spin DRH18.
Be careful changing these settings as RadiMation® is no longer able to verify if the RF Spin DRH18 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: RF Spin DRH18
- Google image search: RF Spin DRH18
