RLC Electronics Inc. CHP-1040
The RLC Electronics Inc. CHP-1040 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the RLC Electronics Inc. CHP-1040:
The frequency range of the RLC Electronics Inc. CHP-1040 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the RLC Electronics Inc. CHP-1040.
Be careful changing these settings as RadiMation® is no longer able to verify if the RLC Electronics Inc. CHP-1040 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
