RadiAntennaDeviceDriverConfiguration
The following tabs are available in the advanced configuration of the RadiAntennaDeviceDriverConfiguration:
The frequency range of the RadiAntennaDeviceDriverConfiguration as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the RadiAntennaDeviceDriverConfiguration.
Be careful changing these setting as RadiMation® is no longer able to verify if the RadiAntennaDeviceDriverConfiguration is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
