RadiAntennaTowerDeviceDriverConfiguration
Note: This page is used to show the configuration of the Raditeq antenna tower related device drivers. This page can now easily be embedded on all relevant device driver pages.
The following tabs are available in the advanced configuration of the RadiAntennaTowerDeviceDriverConfiguration:
There are several methods in which the RadiAntennaTowerDeviceDriverConfiguration can be connected to the PC. The RadiAntennaTowerDeviceDriverConfiguration can for example be connected directly to the PC, or through a plugincard in a RadiCentre 1 or a multi-slot RadiCentre. More information on how to use the RadiCentre is present in the product manual of the RadiCentre. The settings on the RadiCentre tab can be used to specify how the RadiAntennaTowerDeviceDriverConfiguration is connected.
When the RadiAntennaTowerDeviceDriverConfiguration is connected to a multi-slot RadiCentre, also the slot number in which the plugincard is fitted, should be specified.
ScreenElementDescription.svg Directly to PC Specifies that the RadiAntennaTowerDeviceDriverConfiguration is connected directly to the PC, without the use of a RadiCentre.
ScreenElementDescription.svg RadiCentre 1 Specifies that the RadiAntennaTowerDeviceDriverConfiguration is connected to a plugincard that is fitted in a RadiCentre 1.
ScreenElementDescription.svg RadiCentre multi-slot Specifies that the RadiAntennaTowerDeviceDriverConfiguration is connected to a plugincard that is fitted in a multi-slot RadiCentre that also can be manually controlled using the display on the front of the RadiCentre. The slot number in which the plugin card is mounted can also be selected.
ScreenElementDescription.svg RadiCentre multi-slot Ultra Specifies that the RadiAntennaTowerDeviceDriverConfiguration is connected to a plugincard that is fitted in a multi-slot RadiCentre Ultra. This RadiCentre Ultra has no display, and can only be used when remote controlled.
The configuration on the Communication tab should be configured depending on the outgoing connection from the PC. Thus if Directly to PC is selected, the communication settings should be configured as what is actually used between the PC and the RadiAntennaTowerDeviceDriverConfiguration itself. If RadiCentre 1, RadiCentre multi-slot or RadiCentre multi-slot Ultra is selected, the communication settings should be configured as what is actually used between the PC and the RadiCentre. In the configuration where a RadiPower is connected with USB to a multi-slot RadiCentre, which is connected by GPIB to the PC, the communication settings of the RadiPower device driver should thus be GPIB.
If the RadiAntennaTowerDeviceDriverConfiguration is for example connected to slot 3 of a multi-slot RadiCentre which has IP address 192.168.178.95 and is connected by LAN to the PC, the following settings should be configured in the device driver of the RadiAntennaTowerDeviceDriverConfiguration:
  • RadiCentre tab
  • Communication tab
    • Communication Stream: VISA
    • LAN: 192.168.178.95
The following settings can be changed for the advanced antenna tower drivers
ScreenElementDescription.svg Ignore height change Indicate that height changes must be ignored.
ScreenElementDescription.svg Ignore polarisation change Indicate that polarization changes must be ignored.
ScreenElementDescription.svg Move antenna before measurement Indicate that the antenna height must be changed before the test is started.
ScreenElementDescription.svg Start position The position to which the antenna tower must be moved before the test is started.
ScreenElementDescription.svg Move antenna after measurement Indicate that the antenna height must be changed after the test is finished.
ScreenElementDescription.svg End position The position to which the antenna tower must be moved after the test is finished.
ScreenElementDescription.svg Wait time The time that must be wait when changing the polarisation.
The polarizer of the RadiAntennaTowerDeviceDriverConfiguration can be configured to use an external polarizer.
ScreenElementDescription.svg Use external Polarizer Indicate that an external polarizer is used.
ScreenElementDescription.svg Configure Configure the settings of the external polarizer.
The device driver can be configured to be reset on initialization.
ScreenElementDescription.svg Reset device during initialization Configure that the device is reset when initialized.
ScreenElementDescription.svg Delay after reset The time in seconds to wait after resetting the device
Some polarizers have additional settings that can be configured these are shown on the settings panel
ScreenElementDescription.svg Enable sounds Enable or disable sound coming from the polarizer.
The Firmware update tab can be used to update the firmware of the RadiAntennaTowerDeviceDriverConfiguration.
Warning: The firmware update can take a few minutes. During the actual firmware update the window is disabled, and cannot be closed. It is possible that Microsoft Windows shows messages that the RadiMation® software is not responding. Ignore those messages and do not kill, abort or end the software. Also do not disconnect the connection between the RadiAntennaTowerDeviceDriverConfiguration and the PC, while the firmware update is being performed.
