RadiCouplerDeviceDriverConfiguration
| Note: | This page is used to show the configuration of the Raditeq coupler device drivers. This page can now easily be embedded on all relevant device driver pages. |
The following tabs are available in the advanced configuration of the RadiCouplerDeviceDriverConfiguration:
The frequency range of the RadiCouplerDeviceDriverConfiguration as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the RadiCouplerDeviceDriverConfiguration.
Be careful changing these settings as RadiMation® is no longer able to verify if the RadiCouplerDeviceDriverConfiguration is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The forward and reflected attenuation settings of the coupler can be configured.
| The forward power attenuation in dB. |
