How to measure amplifier harmonics using RadiMation
The measurement of the harmonics is often needed to ensure that the used amplifier in the setup is not generating too much power on multiples of the carrier frequency.
As the harmonics are thus present on higher frequencies than the CW signal, all the equipment that is connected to the output of the amplifier up to and including the used spectrum analyser should be able to be used on those higher frequencies. For an amplifier of 80 MHz - 1000 MHz, measuring up to the 6th harmonic, it is thus necessary that the measurement equipment is usable up to 6 GHz.
Overview
There are three possible setups of the used equipment to measure amplifier harmonics. Each with their own advantages, and small differences in the used equipment.
- Measure the power of all harmonics using a spectrum analyser.
- Measure the broadband power with a powermeter and the harmonics using a spectrum analyser.
- Measure the actual field harmonics using a receive antenna.
To use only the spectrum analyser the Forward power meter in the testsite has to be selected to be the spectrum analyser device driver.
Keep in mind to not select any device for the sensor power meter on the 'Devices 2' tab.
Device name |
Tab in testsite configuration window |
suitable for harmonic frequencies |
note
Signal Generator |
Devices 1 |
no
Amplifier |
Devices 1 |
no |
This is the amplifier of which the harmonics are being measured.
Coupler |
Devices 1 |
yes |
Forward power meter |
Devices 1 |
yes |
The powermeter device driver for the analyser that is being used to measure the harmonics.
Device name |
note
Signal Generator |
Devices 1 |
no
Amplifier |
Devices 1 |
no |
Coupler |
Devices 1 |
no |
Devices 1 |
no |
The powermeter device driver for the broadband power measurement of the forward power.
Sensor power meter |
Devices 2 |
yes |
Device name |
note
Signal Generator |
Devices 1 |
no
Amplifier |
Devices 1 |
no |
Coupler |
Devices 1 |
no
Devices 1 |
no |
Calibration antenna |
Devices 1 |
yes |
The antenna that is used for the receiving of the generated electrical fields on the harmonics.
Spectrum analyser |
Devices 2 |
yes |
The device driver for the analyser that is being used to measure the harmonics.
Configuring the calibration
To start the harmonics calibration first, open an EUT file. This EUT file represents the amplifier, which is the actual Equipment Under Test (EUT). By maintaining this EUT file, a yearly remeasurement of the harmonics of the amplifier will all be present in the same EUT file.
Once the EUT file is opened, select from the menu:
Calibration
EUT Calibration
Harmonics
Description
The name of the selected TSF file.
Frequency Range
Sets the frequency specification to a frequency range.
Start
Sets start frequency.
End
Sets end frequency.
Step Fixed
Sets a fixed step size from start to end frequency.
Step Previous Frequency
Sets a logarithmic step size from start to stop frequency
Starting From
Sets the start frequency for a logarithmic step from which the actual measurement frequencies will be calculated. the starting from frequency should be lower then the actual start frequency. The test will start at the first calculated frequency that is equal or higher then the specified start frequency.
Frequency list
With frequency list the operator can select a frequency list file by browsing to the file location. The frequencies inside the frequency list file will be measured.
Constant
The test level can be set to a constant level to which the power should be regulated.
Variable
A .COR file can also be used. This can be the same file as for the Frequency List.
Amount
The number of harmonics that should be measured.
Type of harmonic
If only the even, odd or both (even and odd) harmonics should be measured.
Calibration method
On which power levelling point the desired testlevel should be regulated.
Test Equipment
In the test site window the test engineer can select which equipment list will be used during this test.
Test engineer
In the test engineer window, the test engineer can select its own name. The test engineer name will be stored by the test results
Amount of samples
The amount of measurements that are measured on each harmonic to determine its power. The average of these measurements will be used as the power of the harmonic.
Start Test
Starts the configured calibration.
Cancel
Cancel the configured calibration.
Environment
Display the environment window.
Amplifier
Inputs
Note
Display the note window.
Units
Display the Units configuration window
Reporting
Photos
Genaral info
Calibration procedure
- Set the signal generator to the first frequency and a low power.
- Measure the power using the forward powermeter. If the power is within the desired tolerance, continue at step 4.
- Adjust the signal generator carrier level. If the forward power was too high, reduce the carrier level, otherwise increase the carrier level.
- Use the spectrum analyser to measure the first harmonic
- Use the spectrum analyser to measure the other harmonics that should be measured
- Increase the signal generator carrier frequency to the next frequency. continue at step 2.
Carrier frequency
100 MHz |
200 MHz |
300 MHz |
400 MHz |
500 Mhz
Forward power
56.0 dBm |
56.1 dBm |
56.2 dBm |
56.1 dBm |
56.0 dBm
1st harmonic
55.9 dBm @ 100 MHz |
55.8 dBm @ 200 MHz |
55.9 dBm @ 300 MHz |
55.8 dBm @ 400 MHz |
55.9 dBm @ 500 MHz
3rd harmonic
37.8 dBm @ 300 MHz |
42.2 dBm @ 600 MHz |
52.7 dBm @ 900 MHz |
43.1 dBm @ 1200 MHz |
39.2 dBm @ 1500 MHz
5th harmonic
33.1 dBm @ 500 MHz |
37.4 dBm @ 1000 MHz |
37.9 dBm @ 1500 MHz |
38.4 dBm @ 2000 MHz |
--- @ 2500 MHz
It is possible that one or more of the higher harmonics have not been measured due to limitations of the allowed frequency range of the used equipment (which can be coupler, spectrum analyzer, antenna and cables). For a CW frequency of 500 MHz, the 5th harmonic is generated at 2500 MHz. If however the used spectrum analyzer is only able to measure up to 2000 MHz, it is not possible to measure the 5th harmonic of 500 MHz, and thus the value in the table will be empty. Also the graphline of the 5th harmonic will then only be drawn up to 400 MHz, which corresponds to the 5th harmonic at 2000 MHz, which is the highest measurable frequency of that spectrum analyzer.
Test results
In the test results it is possible to show the forward power measured.
When only a spectrum analyser is used, the forward power will be the same as the first harmonic. When also a broadband power meter is used, the forward power measurement will be the measured broadband power, and it thus will be higher than the power of the first harmonic alone.
Signal power
The power of the signal generator that is driving the amplifier.
Forward power
The (broadband) output power that is generated by the amplifier.
Power (1st harmonic)
The power of the first harmonic (the actual CW frequency) that is generated by the amplifier.
Power (...th harmonic)
The power of specified harmonic that is generated by the amplifier.
Gain (...th harmonic)
The dBc difference between the specified harmonic and the first harmonic.
Std. Dev. (...th harmonic)
The standard deviation of the measured power samples of the specified harmonic.
Conclusion
The harmonics calibration in RadiMation can thus be used in different measurement configurations to measure the actually generated harmonics. Depending on the requirements and the used standard, the best suitable measurement configuration can be used.
