RadiMation Application Note 121
Overview[edit]
Our powermeters are intended to be used in an automated test-setup. And they can also be used in a stand-alone mode to measure power. To use it stand-alone mode you need to install the drivers, install RadiMation free, add the power meter in RadiMation and set it up. This application note will describe all these actions, step by step.
Installing the software[edit]
RadiMation is available for download, without requiring a license. Without a license, RadiMation will start in free mode. If RadiMation is running in free mode, will be shown on top of the RadiMation window.
In this free mode, the RadiMation functions are limited, but it is possible to use the RadiPower in stand-alone mode.
A download link to the latest RadiMation version, is available on our RadiWiki website.
The RadiMation download will also include the driver for the RadiPower.
If the drivers are not loaded automatically, the drivers can be installed manually from the supplied USB key. Follow the normal instructions from Windows to install the drivers manually.
Once the drivers are loaded successfully, the RadiPower® should be shown in Windows Device Manager, under the 'Universal Serial Bus controllers' section.
After installing the driver and RadiMation Free, some additional configuration of RadiMation needs to be performed, to be able to use the RadiPower device. When executing this step, make sure that the RadiPower device is connected.
Installing and configuring the device driver in RadiMation free[edit]
Warning: Make sure that the power meter is detected by windows, and shown in device manager
Warning: The USB device is detected, however the PowerMeter will not work until it is specified how the PowerMeter is connected.
You now may configure additional options:
  • Select the Option tab and set the desired filter for CW measurements, for example: Filter 5.
When the device returns "The check for this device has passed" then the device is correctly configured and RadiMation confirms that the communication is working.
More details on adding a device driver in RadiMation is described in the Device driver configuration section of Chapter 2 of the RadiMation® manual.
The software and the hardware are now installed,, and also the device has been added to RadiMation and it is checked that it works. Now the power meter can be used to measure power and read the measurement.
  • Go to Devices and open Power meters
  • Select the power meter you have just configured (In this example we named the driver: "StandAlone PowerMeter")
This opens a device window for the power meter:
Make sure that the device is connected to your machine via USB. Click on Connect to open the connection to the RadiPower. The red bar will become yellow, while it is connecting. When it is connected correctly it changes green and the button displays Connected.
Powermeterconnected.png]
Once the powermeter is connected, you can read out the values from the power meter. This can be done manually by hitting the Trigger button. This will give you 1 sample of the signal. To measure continuously set the triggering to Auto. The default interval is 1s, but this can be changed to any other interval.
Additional information[edit]
The power meter has now been successfully set up and the first test was successful.
If a correction of the powermeter reading is necessary, for example to correct for cable losses, this can achieved by attaching a correction file to the powermeter device driver. Creating a new correction file is explained in Chapter 14 of the RadiMation user manual. The created correction file can then selected as the power correction of the powermeter.
For more information see these links:
