How to perform an ISO 11452-4 BCI (Bulk Current Injection) substitution test[edit]
This application note explains how the ISO 11452-4 BCI (Bulk Current Injection) substitution test can be performed with RadiMation®.
The ISO 11452-4 standard is used to test the immunity of automotive electronic components to conducted RF (radio frequency) disturbances injected into the wiring harness. The test frequency typically ranges from 1 MHz to 400 MHz, using both continuous and amplitude-modulated signals. The test ensures that the electronic devices can withstand the RF disturbances without performance degradation or failure.
The exact requirements and test methods for the BCI test are specified in the ISO 11452-4.
Necessary equipment[edit]
The following devices are required to run the calibration, verification, and EUT (Equipment Under Test) test:
- Signal generator
- Amplifier
- Coupler
- Forward power meter
- Current sensor
- 50 Ohm load
- 50 Ohm attenuator
- Current injection device
- Current injection calibration jig
Note:
If the current unit is shown as mA, it can be changed to dBmA by clicking Units, select Current and click Edit to change this.
Define the test level[edit]
The ISO 11452-4 BCI test requires test levels to be defined for different frequency ranges. The test level may vary depending on the application class or specific test plan, and these levels are set up as a correction file in RadiMation®.
File
New
Correction
First, create a correction file in RadiMation® and specify the applicable test level for the BCI test based on the test requirements. The levels are typically specified in terms of current in mA for different frequency bands (see 'ISO 11452-4 BCI test severity levels ').
In this example the levels for test severity level 1 are configured.
Ensure that the correction file has a Frequency column and a Current column with the unit set to mA.
File
Save correction Save the test level as a correction file on disk.
This correction file will be used during the calibration and EUT testing.
Calibration procedure[edit]
The calibration procedure is necessary to characterize losses in the setup and determine the correct power level for injection.
Calibration equipment[edit]
Note:
When calibrating at high levels ensure that enough adequate attenuation is used to shield the current sensing device from damage.
Note:
When calibrating using amplifiers rated with more power than the calibration setup can tolerate, ensure that enough adequate attenuation is used after the amplifier to prevent damaging levels from reaching the setup.
The configuration of the calibration test setup should include the following equipment:
Device name |
Tab in test site configuration window |
note
Signal Generator |
Devices 1 |
The signal generator to use
Amplifier |
Devices 1 |
The amplifier to use
Coupler |
Devices 1 |
The directional coupler to use
Forward power meter |
Devices 1 |
The forward power sensor to use
Power meter |
Devices 2 |
The power meter or analyzer for measuring current
Injection clamp |
Devices 2 |
The bulk current injection (BCI) clamp
Calibration jig |
Devices 2 |
The jig used for the current injection calibration
| Cables
| ① |
Cable current -> power meter |
Cables |
Cable with a correction file specified for cable loss
| ② |
Cables |
Cable with specified loss of the used attenuator
| ③ |
Cables |
The BCI test covers four primary frequency bands. The following settings can be configured according to ISO 11452-4 requirements:
The minimal requirements related to the step sizes are found in ISO 11452-1, 5.6 Table 2.
| Band |
Frequency range
| Band 1 |
0.1 MHz - 1 MHz
| Band 2 |
1 MHz - 3 MHz
| Band 3 |
3 MHz - 200 MHz
| Band 4 |
200 MHz - 400 MHz
These four bands can be configured and performed in one calibration. The calibration can be started by selecting:
Calibration
System calibration
Conducted immunity
This example shows an example of the configuration for required for the calibration.
Start
The start frequency of the calibration (e.g., 1 MHz).
End
The stop frequency of the calibration (e.g., 30 MHz).
Step
The frequency step, in this case, 1%.
Test level
The test level, in this case current.
Variable
The variable test level, select the correction file created earlier.
Tolerance
The regulation tolerance.
Calibration method
The power measurement that should result from the calibration: Forward power.
Test equipment
The calibration test equipment.
Test engineer
The engineer performing the calibration.
Calibration result[edit]
Once calibration is complete, the engineer will save the results in a calibration (.CAL) file.
EUT Testing[edit]
EUT Testing equipment[edit]
The configuration for EUT testing should contain the following devices:
Device name |
note
Signal Generator |
Devices 1 |
Amplifier |
Devices 1 |
Coupler |
Devices 1 |
The coupler to use
Devices 1 |
Injection clamp |
Devices 2 |
The bulk current injection clamp
Configure the EUT test[edit]
To perform the EUT test, configure the conducted immunity multiband test by selecting from the menu:
Tests
Conducted Immunity
Multiband
The following bands should be configured:
| Band |
Frequency range
| Band 1 |
0.1 MHz - 1 MHz
| Band 2 |
1 MHz - 3 MHz
| Band 3 |
3 MHz - 200 MHz
| Band 4 |
200 MHz - 400 MHz
Start
The start frequency of the test. For example 0.1 MHz.
End
The stop frequency of the test. For example 1 MHz.
Frequency Step
The frequency step.
Dwell Time
The dwell time.
Frequency Change Mode
Constant.
Modulation
Configure the required modulation.
Test equipment
The equipment needed for the conducted immunity test.
Location Type
Injection clamp.
Test Level
Specify the current substitution method.
Inputs
No inputs are needed.
To configure any required modulation settings click Config next to the modulation settings, click the applicable tab, and enter the modulation settings as specified in ISO 11452-1.
Activate modulation
Check this checkbox to enable the required modulation.
Frequency
The frequency.
Depth
The modulation depth.
Also apply modulation out of the dwell-time period
Check this checkbox to enable modulation outside the dwell-time.
Description
The description of the test level.
Calibration file
Select the calibration file to use for this band.
Test level
Variable current, and specify the correction file for the applicable test level.
Calibration method
Select Forward Power.
Tolerance
Specify the tolerance to use.
4
EUT Test Result[edit]
The RadiMation® Conducted Immunity multiband test can be used to perform the ISO 11452-4 BCI substitution test.
