RadiMation Application Note 161
EIRP[edit]
ERP[edit]
| Ideal dipole radiator antenna diagram. |
| Ideal isotropic radiator antenna diagram. |
| Practical antenna diagram. |
| Gain relative to isotropic antenna. |
| Gain relative to dipole antenna. |
For more information see the following article Gain
Measuring[edit]
A: Area
PD: Power density at a distance R from the transmitter.
Pt: Transmitter power.
G: Gain of the antenna.
Gt: Gain of the transmitting antenna.
Pt: Transmitter power, or the total power emitted by the antenna.
and resulting its EIRP counterpart would be:
