How to perform a MIL-STD-461 RE103, radiated emissions, antenna spurious and harmonic outputs test[edit]
This application note explains how the MIL-STD-461 RE103, radiated emissions, antenna spurious and harmonic outputs test can be performed with RadiMation®.
The "RE103, radiated emissions, antenna spurious and harmonic outputs" test applies as an alternative to CE106 for testing transmitters with their intended antennas, ensuring emissions do not exceed RE102 limits in transmit mode. It is preferred for systems with active antennas or non-standard impedance curves. It applies from 10 kHz to 40 GHz, excluding the signal bandwidth and ±5% of the fundamental frequency, with larger exclusions for high-power Navy shipboard systems.
The exact requirements and test methods for the RE103 are specified in the MIL-STD-461.
Necessary equipment[edit]
- Measurement receiver
- Band rejection network
- Attenuators / filters
- Antenna
Correction files[edit]
Calculate the correction value for the far field[edit]
For the correct calculation of the ERP value the distance (R) is determined. See section 5.19.3.4a for details.
In this example a transmitter dipole antenna for 2.4 GHz is used which is smaller than the receive antenna.
In this case we can use the following formula to calculate the far field distance
where:
is the diameter of the antenna.
is the wavelength.
R = 6.25 cm = 0.0625 meters
To calculate the value for the correction file use the following formula:
The outcome of this formula should be used in a correction file.
In this case the value to correct for is:
Create a correction file for the far field correction value:[edit]
File
New
Correction
First create a correction file in RadiMation® and specify the value of -40 for the applicable frequency range.
Save the correction file on disk and attach it to cable driver that will be used in the test equipment.
EUT Testing[edit]
EUT Testing equipment
The configuration of the eut testing test site should contain the following devices:
Device name |
Tab in test site configuration window |
note
Antenna |
Devices 1 |
The receiving antenna to use
Spectrum analyser |
Devices 2 |
The measurement receiver or spectrum analyser to use
| Cables
| ① |
Cable preamp-> analyser |
Cables |
Cable with a correction file specified for the band rejection filter or high pass filter
| ② |
Cables |
Cable with the specified loss of the used attenuator
| ③ |
Cables |
Cable with a correction file specified for cable loss
Configure the EUT test[edit]
To perform the eut test, create a radiated emissions multiband test.
The radiated emission multiband test, can be started by selecting from the menu:
Tests
Radiated Emission
Multiband
Start
The start frequency of the test. For example 1 MHz.
Stop
The stop frequency of the test. For example 20 GHz.
Reference Level
The reference level set in the analyser. This setting is not used when a receiver is used.
Attenuation
The attenuation set in the receiver.
RBW
The RBW set in the receiver.
Step size
The step size set in the receiver.
Measure time
The measure time set in the receiver.
Preamplifier
The preamplifier setting set in the receiver.
Traces
The type of trace set in the receiver. For MIL-STD-461 RE103 the peak detector is used.
Test Equipment
The equipment used for the measurement.
Location type
The type of measurement that should be used. Set this to Antenna spurious and harmonic outputs.
Max Height
The maximum height for the antenna tower.
Min Height
The minimal height for the antenna tower.
Steps
The number of height positions to measure.
Move during measurement
If the antenna tower can move during the measurement.
Optimize Height
Find the optimal emission around a certain height. This is normally not used during MIL-STD-461 RE103 measurements, and can thus be unchecked.
Distance
The distance between the antenna and the EUT. The antenna distance determined in 5.19.3.4a.
Antenna Polarization
Which polarization is used, Vertical, Horizontal or Both.
Start Angle
The minimal turn table angle.
End Angle
The maximum turn table angle.
Steps
The number of angles to measure.
Turn during measurement
If the turn table can move during the measurement. This is normally not used during MIL-STD-461 RE103 measurements, and can thus be unchecked.
Optimize Angle
Find the optimal emission around a certain angle. This is normally not used during MIL-STD-461 RE103 measurements, and can thus be unchecked.
EUT Angle Offset
The offset of the EUT on the table. This is normally not used during MIL-STD-461 RE103 measurements, and can thus be set to 0 degrees.
Limit Lines
The applicable limit line can be added, in this example the "MIL-STD-461 RE102 XXX-XXX" limit line file.
All peaks above x dB below the limit line
Which level above x dB below the limit line the peaks should be detected.
Peak detection
How many peaks should be detected automatically. For a MIL-STD-461 RE103 peaks will be selected manually
Final peak measurement
It is possible to perform a final measurement on a peak with the selected detectors. Normally no final measurement is needed for the MIL-STD-461 RE103 measurement, and all detectors can thus be unselected.
