RadiMation Error: 33564833
The file '<FILENAME>' cannot be opened.
During the generation of a Microsoft Excel report with the report generator, it is detected that the to be generated report file cannot be opened in Microsoft Excel. The exact reason for this problem could be caused by several reasons.
Solution
  • Determine if the specified filename is present on the specified location.
  • Try to open the specified filename manually in Microsoft Excel, and investigate why the file cannot be opened.
Be aware that it is not allowed by Microsoft Excel that files with a .XLSM extension are renamed to files with a .XLSX extension. Those renamed files cannot be opened in Microsoft Excel. For this reason, it is only allowed to generate a report with the same extension as the extension of the specified template. If the template file has a .XLSM extension the specified filename that should be used for the report also should have a .XLSM extension.
